#1 (permalink) |
Just got a 09 Foreman, foot shift with power steering. BTW don't knock power steering until you've tried it. It is nice.
Anyway that front plastic had to go. I like the stock look so I went from there. Cut out the center mount ears, added a center piece of pipe, used some half inch expanded metal to fill it in. For now I put the lower poece of plastic on as it does add some protection. I may cut it down lower as it does offer some protection. I added the class 1 receiver in the middle because I use a multi mount winch on mine, most of the time I leave the winch off. And actually I use it more on the rear of the atv. Some pics...
2009 Foreman TRX400FPM9 |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
Very nice! I wish I was that talented. I just ended up buying the aluminum products plate which has worked out pretty good.
2006 Honda Foreman S 3000 lb. Viper Winch Aluminum Products Skid Plate/ stick stoppers |
#5 (permalink) | |
QUOTE (mistyandgary @ Jan 18 2010, 05:57 PM)
Quote:
now got to save up a few more Coins to get the rest of the Belly pan and CV Guards...ohhh yeaaaaa |
#7 (permalink) | |
QUOTE (wydglide @ Jan 18 2010, 05:48 PM)
Quote:
When I went shopping I looked at the 09 Rancher (foot shift and power steering) at the same time. I actually switched back and forth TWICE while at the dealership. The rancher had fuel injection and was water cooled. The rancher was very quick(not all what I needed), but the tranny is a wider ratio, no low first gear. The rancher also has NO pull start. You can add one for about $200 the sales guy said. This was a big strike against the rancher. I have gone up to the camp more than once and found the battery dead...as in it will not take a charge. Instead of taking time to find a battery, I pulled started it all weekend with no problem. The rancher with FI does start a lot easier on a cold morning. My 03 rancher is cold natured to. In the end I liked the 3rd headlight(now blocked by my rack, the instrument panel I liked better, the pull starter, and the slight bigger size. Also what sealed the deal is we loaded in into my pickup and I could close the tailgate. I have a 8' bed but a Tractor supply 16" deep toolbox. Once the tailgate closed I said I'll take this one! With my bumper mod it's even slightly shorter the way the plastic sticks out. Thanks, Rob
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
