06 500 foreman 4x4 engine oil capacity - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 06-08-2009, 06:20 PM   #1 (permalink)
Default
Recently i changed my oil in my o6 500 foreman 4x4. I bought 6 quarts of amsoil synthetic because the guy who sells it says my bike takes over 5 quarts, well when i drained it i knew that was not close, i opened the dipstick plug when i drained it and i changed the filter, i called a honda atv shop and they said over 5 quarts as well, i would like to hear from others who changed their oil and hear how much they had to use to fill it back up. Mine took about 2 and a half quarts after starting it up between checks, also has anyone else used a k&n oil filter, the one i used did not have what i think is a check valve on the motor side of the filter like the honda one i took out. opinion's welcome
trx350first is offline   Reply With Quote
Old 06-08-2009, 06:50 PM   #2 (permalink)
Administrator
toodeep's Avatar
Default
The Foreman will take around 2 1/2 qts and the Rubicon will hold over 5 qts.
A 420 and 300 with some stuff...
Old 06-08-2009, 06:51 PM   #3 (permalink)
Honda Addict
Default
On a true Foreman the oil capacity is about 2.5 Qts. The Rubicon takes a little over 5 Qts.
2007 Red Rubicon
26x9x12 & 26x12x12 Maxxis Bighorns
Kolpin Dirt Works 2" reciever hitch
Kolpin Hand Guards with mirrors
Garmin 60 csx GPS with Ram mount
Kimpex Outback rear trunk seat
Kimpex Fender Guards with foot rests
Top Light on a switch
Clipped carb spring
Strong Made Stick Stoppers (Double Sided)
lt.rubi is offline   Reply With Quote
Old 06-08-2009, 06:56 PM   #4 (permalink)
Default
They both must be considered trx 500's and if that is true that's why there is confusion, why the dealer told me that after i specificly told him a foreman i can't figure. Thank you for your responses now about the k & n filter issue
Old 06-10-2009, 07:28 PM   #5 (permalink)
Default
Just got through changing my oil, my 07 foreman 500 takes 2.6qts. asked my dealer to make sure.
bkearby2006 is offline   Reply With Quote
Old 06-10-2009, 08:53 PM   #6 (permalink)
Honda Lover
mischievous_james's Avatar
Send a message via Yahoo to mischievous_james
Default
yeah dad has a 07 rubi...we was shocked at how much of a oil difference there is . but, when u take a closer look the motors arent even the same. my foreman is 475 cc air cooled where dads rubi is 499 liquid cooled. im assuming that the additional oil the rubi takes is for the transmission?
08 foreman 500s (white) kimpex bumpers, gorilla hitch, warn winch,quadrax rear seat, fender protectors. coming soon: wheels, skins, springs.
mischievous_james is offline   Reply With Quote
Old 06-10-2009, 10:17 PM   #7 (permalink)
Kipes's Avatar
Default
Not to change the subject but I went to the dealer and asked for a oil filter for a my Foreman 500 and he gave me one for a rubicon I think cause it was way bigger. When I brought it back and told him its the wrong one and want my money back because I found the right one at the autoparts store he kinda gave me a dirty look.
2006 Foreman 4x4 500s
Powermadd handguards
2.5 Warn winch
2" Perfex long travel lift kit
High Lifter springs
26-12-12 Executioners on rear
26-10-12 Executioners on front
Douglas Rattlesnake rims
3rd Headlight switch
Moose Heated Handgrips and thumb warmer
Replaced the stock silver engine covers and front skid plate with 07 camo black and painted front brush guard black
2005 Rancher 350ES 2wd
2001 Polaris 325 Trailboss 2wd
Kipes is offline   Reply With Quote
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
