Rear Brake Drum Pads How To? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 20 (permalink) Old 04-16-2007, 03:13 PM Thread Starter
I am looking to replace my Rear Drum pads tonight. I just bought the Foreman and I have never replaced drums before. I have always had racing 4-wheelers that had discs all the way around.
What I am experiencing is that when I step on the brake pedal or pull the left lever, they go all the way down and never return. I have cranked up the adjustments on the outside of the drum and it did nothing. I have new drum pads and I am ready to get started.
My question is what to do next. Does anyone have a how to for this? How about some instruction. I don't want to mess anything up worse than it already is.
Thanks in advance for your help!
2005 500 S Foreman (Red)
2500LBS WARN Winch
27" Swamp Lites
Big Foot Kit
bobbybog is offline
post #2 of 20 (permalink) Old 04-16-2007, 03:20 PM
Send a message via MSN to cra5h Send a message via Yahoo to cra5h
i don't know where to start with brakes...
i have a similar problem, when i use the rear brakes they don't stop, but if i turn the adjustment a little, they are on all the time...
i should just change them too, but like you, i haven't messed with drums either...
2005 Foreman 500 S
- 27" Maxxis Mudbugs on Painted Stock Rims
- HMF Exhaust
- HMF Jet Kit
- K&N Highflow Filter
- Outerwears Prefilter
- Highlifter Springs
- Aluminum Products Full Skid and Arm Guards
- NGK Iridium Plug
- All decals removed
- Custom Snorkel (2"pvc throughout)
- Custom Dented Bumpers (Front and Rear)
- Custom Front Tow Hook
- Custom Painted Racks
www.cra5h.com
cra5h is offline
post #3 of 20 (permalink) Old 04-16-2007, 03:54 PM
Start out by removing the right rear wheel,remove tin brake shield,remove cotter pin and axle nut then you can slide off the rear drum.The shoes are held on by springs just remove them and then re-install in the reverse order.While you have the drum off,clean it out real good,use sand paper on the inside if necessary then grease the rubber lip seal before re-instaling.I hope this isn't confusing,i didn't intend it to be but once you get started into it I think you'll be able to figure it out.
Oh yeah,one more thing,I've ran into this alot on Honda's.The foot brake lever seizes on the pivot shaft,remove the foot lever from the pivot clean it up really good the apply never seize compound before putting it back on.
2006 Foreman 500 S
25" GBC Dirt Devils
26" Kenda Executioners
ITP silver steel wheels
Warn multi-mount
mile marker 2500 winch
VDO cyl. head temp. gauge
HMF utility series muffler
Dynojet kit/running DJ170
Yooperforeman is offline
post #4 of 20 (permalink) Old 04-16-2007, 03:57 PM Thread Starter
Do you also pull the hub after pulling off the nut?
2500LBS WARN Winch
27" Swamp Lites
Big Foot Kit
bobbybog is offline
post #5 of 20 (permalink) Old 04-16-2007, 04:12 PM
H4
Re: Rear Brake Drum Pads How To?
QUOTE ("bobbybog":8g07gfmq)
Do the brakes work when you apply them? Worn shoes should not keep the levers from returning when you release them. Check the handbrake and footbrake cables to make sure they are moving freely. Also make sure the brake lever on the rear drum is free. Make sure all these parts are operating smoothly and levers return to proper position before you tackle the shoes.[/url]
95 FOREMAN 400
27" Super Lights, ITP SS106 Wheels
Int. & Exh. Snorkles, Ext. Vents
Warn 424 , Clipped Carb Spring , NGK Iridium
Perfex Lift, HL Springs, Full Skid Plate
Custom F&R Bumpers
F&R Champion Winches
55W Floodlights, 80/100W Center & Switch
Shift act. Reverse Light
Custom LED Brake/Tail Lights
Fan Switch , 12 Volt Outlet
GOLIGHT Wireless rc Searchlight
Rear Seat , Cooler, Toolbox
Garmin 12 GPS ,Gun rack
H4 is offline
post #6 of 20 (permalink) Old 04-16-2007, 04:54 PM Thread Starter
The pedal and lever do not return at all. I turned the adjustments all the way clockwise on the outside of the drum. One problem I have is that I am having trouble turning them back to bring them back out. Any ideas?
2500LBS WARN Winch
27" Swamp Lites
Big Foot Kit
bobbybog is offline
post #7 of 20 (permalink) Old 04-16-2007, 05:22 PM
H4
Try moving the brake arm behind the rear wheel to see if it moves freely back and forth. This arm should move forward easily causing the brake cam to move the shoes closer to the drum. It should spring back towards the rear when you let go allowing the shoes to move away from the drum. If this cam is not moving freely it will have to be cleaned or freed up. If this arm is free but the levers don't return, the problem is your brake cables. They will need to be freed up and lubed or replaced.
If you have the adjusters turned all the way clockwise you have the brakes engaged and there will not be enough movement in the cable for the levers to return. Back the adjusters all the way off and check the arm for free movement.
95 FOREMAN 400
Custom F&R Bumpers
H4 is offline
post #8 of 20 (permalink) Old 04-16-2007, 05:25 PM
I replaced mine last week it was real easy,,once you get into you will figure it out.It took me about an hour.
big urn is offline
post #9 of 20 (permalink) Old 04-17-2007, 09:42 AM Thread Starter
I got a whole different problem now. I never even got the wheel off. I have 1 lug nut that when you turn it the entire stud turns. The stud is completely loose and it will slide back and forth. There isn't enough room to get behind the wheel and cut it off or anything. I worked and worked trying to get it off.
Here is what I have done:
1. After trying and trying, then taking a break so I didn't just rip the stupid wheel off, I ended up trying to split the nut.
2. I split the nut and have it split almost all the way through, but I can't get it to budge anymore. I broke 3 screwdrivers trying to split the thing.
3. I heated the nut until it was cherry thinking that this would allow me to bust it easier. No luck.
4. I then figured I would just take off the castle nut and remove the whole hub. Two problems with that, one is that I can't seem to get the cotter pin out due to the small space in the ITP wheel, second problem is that I don't have a socket to fit the nut anyway. What size is the nut?
Can someone please help before I really break something?
2500LBS WARN Winch
27" Swamp Lites
Big Foot Kit
bobbybog is offline
post #10 of 20 (permalink) Old 04-17-2007, 09:48 AM
H4
Cut the lug nut away from the stud with a mini grinder or split it with a proper cold chisel, not a screwdriver.
95 FOREMAN 400
Custom F&R Bumpers
H4 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
