Carb. Float issue - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 02-11-2007, 08:15 PM   #1 (permalink)
Send a message via MSN to cra5h Send a message via Yahoo to cra5h
Default Carb. Float issue
I have an issue where my float gets stuck and gas flows into my airbox, the only way to stop it is to turn the fuel off and wait until it drains...i took off the four screws on the top of the carb and moved the little needle thing around and put it back together and it seemed to work fine for an hour, then it died and i had to do the same thing again.
i have been told tons of times that the float is stuck but i have no idea where it is or how to get to it.
if anyone can help me out with a description or a pic that would be awesome. i appreciate any help that i can get.
thanks
2005 Foreman 500 S
- 27" Maxxis Mudbugs on Painted Stock Rims
- HMF Exhaust
- HMF Jet Kit
- K&N Highflow Filter
- Outerwears Prefilter
- Highlifter Springs
- Aluminum Products Full Skid and Arm Guards
- NGK Iridium Plug
- All decals removed
- Custom Snorkel (2"pvc throughout)
- Custom Dented Bumpers (Front and Rear)
- Custom Front Tow Hook
- Custom Painted Racks
www.cra5h.com
cra5h is offline   Reply With Quote
Old 02-11-2007, 08:22 PM   #2 (permalink)
Default
When you change the jet on your carb you will have access to it on the bottom of the carb. Just gently spray it clean while you have the bottom cover off.
2005 Honda Foreman 500 ES
The kitchen sink is on backorder...
Truegrit is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
