Clutch replacement help - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 14 (permalink) Old 03-01-2017, 01:35 PM Thread Starter
I am still getting clutch slip in 4th and 5th only when the quad is cold. I have adjusted it correct and changed the oil so it's time to replace the clutch. Can someone give me a list of parts to get that are clutch related as I only want to open it up once. Thanks
Crombie1 is offline
post #2 of 14 (permalink) Old 03-01-2017, 02:23 PM
jeepwm69's Avatar
Garage
Still a 2012?
Honda ATV Parts 2012 TRX500FM CLUTCH Diagram
If it were me, I'd replace 12 and 12. My guess is the drum will be grooved. Safe to figure on doing 3 and 4 (discs) on the change clutch while you're in there too
If you have a lot of miles on it, you might also consider 26, 10.
17 and 18 are considered "buy new" nuts, but I normally reuse the old ones.
Get a tube of Hondabond/ Yamabond/ Threebond to use on the front case when you reinstall it.
Be sure and break loose and grease your clutch adjuster screw while you have the front cover off.
"The Good One"
2009 Foreman 500FM Green
27" Execs on Rubicon rims, Perfex
5K Viper Max winch
"The Wreck"
Perfex with HL springs
27" Mudbugs on Rubicon rims
Heated Grips and Thumb, HID's
4K Viper Max winch
"The Project"
2006 Foreman 500FM Green
27" Titan 589's Perfex with HLsprings
3K Superwinch winch
"Sandy" aka the wife's
2009 475 Rancher AT Tan
26" Mudbugs on Rincon rims
jeepwm69 is offline
post #3 of 14 (permalink) Old 03-01-2017, 02:51 PM Thread Starter
Is the clutch adjust screw available to buy ? Last time I adjusted it one lug broke
Crombie1 is offline
post #4 of 14 (permalink) Old 03-01-2017, 02:54 PM Thread Starter
Also. Is there a gasket on the front cover ? And is there any special tools I may need ?
Crombie1 is offline
post #5 of 14 (permalink) Old 03-01-2017, 03:17 PM
jeepwm69's Avatar
Garage
#15 is clutch adjustment screw
Honda ATV Parts 2012 TRX500FM FRONT CRANKCASE COVER Diagram
Doesn't look like there's a gasket on the 2012. It's pretty much a 420 engine with a few changes, and the 420's just use Hondabond between the cases.
You'll need a puller to get the cent clutch off. I use a cheap 3 jaw puller I bought on Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Impact will help get the clutch nuts off. If you don't have an impact you can stick a leather welding glove in the gears to keep the clutches from spinning while you break the nut loose. The leather will keep the gears from spinning but won't hurt anything (except the glove).
Other than that it's simple hand tools. You can stand the machine up on the rear rack and work on it standing up. That's how I did it on the 07 Rancher I had.
"The Good One"
5K Viper Max winch
"The Wreck"
4K Viper Max winch
"The Project"
3K Superwinch winch
jeepwm69 is offline
post #6 of 14 (permalink) Old 03-01-2017, 03:50 PM Thread Starter
This is starting to sound like it's out of my capabilities
Crombie1 is offline
post #7 of 14 (permalink) Old 03-01-2017, 04:13 PM
jeepwm69's Avatar
Garage
It's really not that bad
Undo skid plate and floorboards
Stand wheeler up on rear rack.
Undo all the bolts holding the front cover on, and take it off.
Undo clutch nut on centrifugal clutch, remove it. Undo 4 bolts on top of change clutch, and then nut on change clutch, remove it.
On a table, take the clutches apart, replace the parts I mentioned above, and reinstall clutches.
Sealant on front cover, bolt it back on.
Done.
Think of it as a puzzle for adults.
"The Good One"
5K Viper Max winch
"The Wreck"
4K Viper Max winch
"The Project"
3K Superwinch winch
jeepwm69 is offline
post #8 of 14 (permalink) Old 03-02-2017, 08:03 AM
Love this reply - basically told you how to do it in under 100 or so words...
You can do it bud...like Jeep says - think of it as a challenge - then when you succeed, it is that much sweeter and you will gain the knowledge and experience to progress onto bigger things...
2002 450s
SIXSTRINGS is offline
post #9 of 14 (permalink) Old 03-02-2017, 09:57 AM
jeepwm69's Avatar
Garage
Watch this video Crombie.
Engine is on the bench, but you can see how it comes apart. About the 5 min mark is where he takes the front cover off.
You can do this with the engine in the frame, and if you stand the wheeler up on the rear end you'll be working at chest level so not too bad.
"The Good One"
5K Viper Max winch
"The Wreck"
4K Viper Max winch
"The Project"
3K Superwinch winch
jeepwm69 is offline
post #10 of 14 (permalink) Old 03-20-2017, 03:28 PM Thread Starter
Sorry to dig this up but at the start you said to get parts 12 and 12. Did you mean 11 and 12 ?
Crombie1 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
