Hello,
It all started after I accidentally flipped it on the side. I took the head off and found the decompressor on the cam had shattered. I replaced the entire cam assembly with a used one from ebay and took out all the metal chunks. I also adjusted my valves to spec. However the engine still has a constant tapping at top area cant pin point but it was not like this before the flip. Also the timming chain was nice and tight so I didn't mess with it. Please help. Thank you!
