New guy here not new to honda 4 wheelers . Looks like it should get its oil to the top end up one of the studs and galley dispersed to the rocker arms . It is dry . Pushrods are wet at the bottom end and engine is still running with no rod knock or piston noise . Diagram shows oil route from cooler thru the case to the galley and up ? Possibly plugged or has anyone run into this before ? Any help appreciated. Thanks guys .Red
What did you find was the problem. I'm having the same issue.
Related Threads
Honda Foreman Forums
537.3K posts
43K members
Since 2005
