Battery Charging Saga Continues :( - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 65 (permalink) Old 05-15-2012, 09:44 PM Thread Starter
Spiider's Avatar
So just a brief history, I had replaced the battery when I got this quad last winter and it ended up draining shortly after. So I replaced the regulator/rectifier. That didn't work either, so I brought it to a dealer and they said the Stator was bad (whole different dramatic story I won't go into). So they replaced the stator. The battery drained again... But this was like the 5th time so I got yet another new battery and had them test it in the store before I purchased it. Roughly 20 hard hours later the battery dies yet again... Back to the shop and they replaced all the wires coming out from the rectifier. They said it is charging consistently now (at idle 13v and revved at 14v). I get it out again and after riding it for a while again the battery dies... I bring it back to them and they say they can't find anything wrong, that it is charging just fine. I checked it myself just now with the multi-meter and it is at 13v at idle and 14 revved up. The only suggestion they had was to buy and install a voltmeter and watch the volts as I'm riding it and see if the problem only happens when it gets a lot of use. Any suggestions? I'm really upset that this has been an ongoing saga for about 2 months now. I just don't know what to do anymore, seriously thinking about cutting my losses and sell the thing.
2012 Foreman 500 ES/EPS
Bungee Cords for Securing Stuff
Plastic Crate for Various Tools and Accessories
Trailer Hitch
2000 Foreman 450S (sold)
2000# Warn Winch
Cycle Country Plow
Spiider is offline
post #2 of 65 (permalink) Old 05-15-2012, 09:48 PM
scottl1346's Avatar
Send a message via AIM to scottl1346
the starter solenoid can drain the battery while sitting overnight have you changed that?
02 foreman 450 ES
Wiseco high comp piston
2 inch HL lift kit REMOVED
super ATV front disk brake conversion
Super ATV Rear disc conversion
27" zillas on OEM wheels
14% gear reduction
HMF ECO system exhaust
diamond plate bash plate and cv boot guards
Super-winch 2500lb
custom LED brake lights
fan switch mod
rear progressive 512 shocks
100w shark audio system
scottl1346 is offline
post #3 of 65 (permalink) Old 05-15-2012, 09:53 PM
rich450es's Avatar
take off the negitive battery cable and take a test light and touch the end of the negitive battery terminal and the negitive on the battery . if the test light , lights up then you have a draw.....which is why youre battery is draining
2000 foreman 450 es-s
the f**king pig
SOLD
yellow 2003Rubicon all stock and gona stay that way !!!!
red 2000 foreman 450es
1990 Honda 300 4x4 blue stock with plow
friend me on facebook
i love (.)(.)s
rich450es is offline
post #4 of 65 (permalink) Old 05-15-2012, 10:02 PM Thread Starter
Spiider's Avatar
Quote:
The battery doesn't appear to drain when it isn't used for a day or even a few days though.
Trailer Hitch
2000# Warn Winch
Cycle Country Plow
Spiider is offline
post #5 of 65 (permalink) Old 05-15-2012, 10:04 PM
Honda Lover
SWebb's Avatar
Then remove fuses one by one and see when light goes out to narrow it down to which circuit it is on.
2012 Honda Rancher
A.K.A (SWAMP GRAVY)
28" outlaws Skinny/Wide
Sti Hd2 12" Rims
White Body Kit
Swing arm skid plate
Superwinch 3000
Cycle Country cv boot guards
K&N Filter
2003 HONDA TRX90
Soon to find more options
http://www.flickr.com/photos/stevenwebb/
SWebb is offline
post #6 of 65 (permalink) Old 05-15-2012, 10:04 PM Thread Starter
Spiider's Avatar
Quote:
What kind of a test light would I use? The only one I know of is like an outlet test light.?.?
Would I do this while it is not running I assume?
Trailer Hitch
2000# Warn Winch
Cycle Country Plow
Spiider is offline
post #7 of 65 (permalink) Old 05-15-2012, 10:11 PM
rich450es's Avatar
it would be for 12volt use like in the picture
and not running
the f**king pig
SOLD
i love (.)(.)s
post #8 of 65 (permalink) Old 05-15-2012, 10:15 PM
Kipes's Avatar
Might be a very small voltage drain, use a milliamp tester in place of the light and that will also tell you if theres a drain.
2006 Foreman 4x4 500s
Powermadd handguards
2.5 Warn winch
2" Perfex long travel lift kit
High Lifter springs
26-11-12 Sedona Ripsaws on rear
26-9-12 Sedona Ripsaws on front
Douglas Rattlesnake rims
3rd Headlight switch
Moose Heated Handgrips and thumb warmer
Replaced the stock silver engine covers and front skid plate with 07 camo black and painted front brush guard black
2005 Rancher 350ES 2wd
Kipes is offline
post #9 of 65 (permalink) Old 05-15-2012, 10:16 PM
scottl1346's Avatar
i must have a drain on my atv then because i tried this and it lights up (dim) but noticeable and iv never had a dead battery even after letting it sit for weeks in the winter
02 foreman 450 ES
14% gear reduction
Super-winch 2500lb
fan switch mod
post #10 of 65 (permalink) Old 05-15-2012, 10:18 PM
Honda Lover
SWebb's Avatar
Remove fuses one at a time and put them back in and move to next fuse.When light goes out concentrate on that circuit
2012 Honda Rancher
A.K.A (SWAMP GRAVY)
Sti Hd2 12" Rims
White Body Kit
Superwinch 3000
K&N Filter
2003 HONDA TRX90
SWebb is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
