Cheap low-tech rear brake repair - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 02-06-2012, 10:21 PM   #1 (permalink)
Default Cheap low-tech rear brake repair
I got tired of fighting rear brake lever not returning so I intalled a spring I had laying around...Cheap low-tech rear brake repair-rsz_1rear_brake.jpg
99 Foreman stock
03 Rancher
mokanrancher is offline   Reply With Quote
Old 02-06-2012, 10:36 PM   #2 (permalink)
mac102004's Avatar
Default
Your picture is about the size of a postage stamp. Do you have something a little bigger?
'10 Outty 800R XT
mac102004 is offline   Reply With Quote
Old 02-06-2012, 10:37 PM   #3 (permalink)
lop3r1's Avatar
Default
post a larger picture...
07 foreman s camo
2" hl lift
1" hl wheel spacers
27" outlaws
epi/hl outlaw clutch kit
hmf utility, uni filter, dynojet kit
3000lb superwinch
triangle snorkel kit
herculiner on racks/front bumper
custom front recovery point
lop3r1 is offline   Reply With Quote
Old 02-06-2012, 11:42 PM   #4 (permalink)
Administrator
toodeep's Avatar
Default
I've used old springs from the brake shoes to pull the lever back on mine for a sticky cable. Just no point in fixing it in the summer months when it gets dunked every weekend. I just used a little wire to make the hook points but basically the same as what your using except yours is pushing instead of pulling.
Old 02-07-2012, 06:50 AM   #5 (permalink)
Honda Lover
brutus750i's Avatar
Default
u could also tie a rock to the rear rack an push it off when needed,or fred flintstone it! just pickin lol!
29.5 wide laws on all 4 corners on 12 inch ss wheels,full snorks front an rear,homemade winch bumper with 2500 winch,2 in lift with hl springs,14% gear reduction,rear led brake light,disc brakes,tool tubes,a arm skids,2.5 inch rear spacers,cut floorboards with frame riser mod all this on an 04 foreman. kids 01 foreman on 27 mud machine tri claws wide on all 4 corners,snorked.
brutus750i is offline   Reply With Quote
Old 02-07-2012, 01:26 PM   #6 (permalink)
Default
I'll research on posting larger pics. Basically it's a heavy spring surrounding cable between brake cam/lever and fron cable holder. Its a liitle stiff but I know I'm not dragging brake shoes off.
99 Foreman stock
03 Rancher
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
