rear brake not working?? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-31-2012, 07:44 AM   #1 (permalink)
montanaforeman's Avatar
Default rear brake not working??
I am having some problems with my rear brakes. I have adjusted the ARM and the cables and it seems that the shaft that goes into the back of the brake is seized up. Is this just a good time for a tear down clean and change the shoes? And is it possible to get everything moving again or am I in for a rebuild?
2002 Honda Foreman 450es
2000lb superwinch
2" Highlifter lift kit
27" Dirt Devils
Moose plow
Highlifter springs
Local 265 sheet metal worker
montanaforeman is offline   Reply With Quote
Old 01-31-2012, 08:27 AM   #2 (permalink)
Honda Addict
FuzzyD's Avatar
Default
I had the same problem, I just tore it down an cleaned it up now they work, I also had to move tha brake arm on tha cam back a lot becuz my lines were stretched. My brake pads were fine so I didn't change em. Good luck!
2000 foreman 450s. For sale as soon as she runs right!
Stockers
2002 grille and headlights
2 inch hl lift
2011 can am outty 800xtp
Can Am rad relocator
SYATV Snorkles
Gorilla 2" lift
Warn 2500
14" m12 diesels
30" moto monsters, 30x10x14 all tha way around.
Hmf swamp series xl
Red primary spring
Future mods:
///primary
machined secondary
Lte full duals
lte programmer
Twin air filter
Audiopipe
FuzzyD is offline   Reply With Quote
Old 01-31-2012, 08:54 AM   #3 (permalink)
Default
Kinda what I was thinkin. I am also gonna do the trick with the grease fitting rich has talked about.
2000lb superwinch
27" Dirt Devils
Moose plow
Highlifter springs
Old 01-31-2012, 09:43 AM   #4 (permalink)
Honda Addict
FuzzyD's Avatar
Default
Yeah, rich knows his stuff!
Stockers
2 inch hl lift
SYATV Snorkles
Gorilla 2" lift
Warn 2500
14" m12 diesels
Hmf swamp series xl
Red primary spring
Future mods:
///primary
machined secondary
Lte full duals
lte programmer
Twin air filter
Audiopipe
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
