WIll not run please help me - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 01-29-2012, 06:37 PM   #1 (permalink)
Default WIll not run please help me
Okay I have posted a couple of other threads but I thought I would start a new one. I have aquired a 2003 Honda Foreman 450 FM and I got it cheap beacause it wouldnt run and they did not Know why. I am pulling my hair out trying to figure it out. I removed and cleaned the card, I checked the valves and mad a minor adjsutment, I checked the timing (could only check it when cranking) and it checked out fine, compression seem good, getting spark, new plug, getting fuel, gas in tank, petcock on, and all lines are clean and clear. The one thing that I can tell you is there is a lot of fuel bieng blown back into the airbox and I know this is not correct. The machine will fire breafly when I use starter fluid. I have worked on it for a couple of days now and need some insight if anyone has it.
Supertrick is offline   Reply With Quote
Old 01-29-2012, 06:41 PM   #2 (permalink)
rich450es's Avatar
Default
how are the valves ? are thay adjusted to spec
2000 foreman 450 es-s
the f**king pig
2500lb warn winch
foreman 450 parts for sale
pm me for info
Old 01-29-2012, 06:41 PM   #3 (permalink)
Wingman's Avatar
Default
Try adjusting the valves?
Honda 1998 Foreman 450s (Starburst Yellow)
SS ATV 2in lift
Maxxis Bighorn 2.0 tires
Aluminum Products Bash plate
Viper 3500 winch & Cycle country 52in plow
ES floorboard conversion
HONDA!!! No Wing! No Prayer!!
Wingman is offline   Reply With Quote
Old 01-29-2012, 06:44 PM   #4 (permalink)
Default
I went by the book on adjusting the valves and they were pretty close. I did notice that the adjusting screw is not perfectly parallel with the top of the valve. Is that normal.
Old 01-29-2012, 07:02 PM   #5 (permalink)
Honda Lover
brutus750i's Avatar
Default
when checking the timing what mark do you see thru the access plug?also if in doubt pull the plug an stick a screwdriver into the plug hole an see if the piston is at the top of the cylinder too then look at site plug an you should see the letter t. anyone correct me if im wrong but i think im right.
29.5 wide laws on all 4 corners on 12 inch ss wheels,full snorks front an rear,homemade winch bumper with 2500 winch,2 in lift with hl springs,14% gear reduction,rear led brake light,disc brakes,tool tubes,a arm skids,2.5 inch rear spacers,cut floorboards with frame riser mod all this on an 04 foreman. kids 01 foreman on 27 mud machine tri claws wide on all 4 corners,snorked.
brutus750i is offline   Reply With Quote
Old 01-29-2012, 07:03 PM   #6 (permalink)
Wingman's Avatar
Default
Id do a compression check because it sounds to me that you have a intake valve not closing enough and Im thinkin thats why you are getting fuel blown into airbox?
One of the guys that work on these things for a living will chime in soon and may have better ideas.
SS ATV 2in lift
Old 01-29-2012, 07:13 PM   #7 (permalink)
Default
That will be great. I was thinking about the valves and when I was adjusting them I never looked to see if they were functioning properly, maybee one is stuck or something. I am going to go back out and check it, if I dont it will bug me.
Old 01-29-2012, 08:06 PM   #8 (permalink)
Default
okay I triple checked the valves and the timing mark. The timing mark is on the T and I pulled the plud and I could see the top of the piston. I would watch the valves as I pulled it over and they didnt seem to be opening and closing one after the other. It would be one open then the other would look like it might open but not the the one would open again and the other would open just fine. I am no expert but wouldnt they be opening alternatley all the way? Why would the one open in one stroke and not the other? Also after a random pull start one valve would have a 1/4" between the screw asnd the valve and the other would be tight. Are tey supposed to be at the same gap all the time or not?
Old 01-29-2012, 08:15 PM   #9 (permalink)
rich450es's Avatar
Default
does the valve get stuck ? it may have a broken valve seat (the valve seat pulls out of the head ) you may have to pull the head to check it
the f**king pig
2500lb warn winch
pm me for info
Old 01-29-2012, 08:23 PM   #10 (permalink)
Default
I watched it and one valve (after I pulled it over) would be open and then slowly close back.
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
