#21 (permalink) |
The piston walls look good and there is no slop in the piston. I will soak the carb and clean it again. The carb heater wires have been cut but I wouldnt think tht would effect it running, please correct me if I am wrong. Now I wait on a gasket kit. Thanks for all the input and if anybody has more ideas let me know. I will update soon, hopefully with a running Honda.
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) |
id clean the carb good and check the valve lash make sure your on TDC and not TDC on the compression stroke
02 foreman 450 ES 2 inch HL lift kit super ATV front disk brake conversion 27 inch Zillas 14% gear reduction HMF ECO system exhaust diamond plate bash plate and cv boot guards Super-winch 1500lb winch will upgrade someday lol custom LED brake lights |
#23 (permalink) |
Okay I have received the carb rebuild kit today and have yet to put it on but I found out some info from the previous owner that mint lead to a solution if anybody has any suggestions. The foreman has an aftermarket pipe on it and he said he had it jetted. My question is what would happen if I put a factory rebuild kit back on the carb and leave the aftermarket exhaust? Also could this been part of my original problem?
#24 (permalink) |
most likely will be to lean making it run hot
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
