2000 450 es works as long as shift motor isn't touching engine - Page 3 - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Old 06-16-2011, 12:31 AM   #21 (permalink)
Helmut's Avatar
Default
Quote:
Originally Posted by rich450es View Post
i was thinking of the shaft that the foot shifter bolts too
Yeah, you can change it by removing the rear crankcase cover and removing the one bolt that holds it in.
2000 Foreman 400
2004 Grizzly 660
Both stock, except for Mudlites and Kimpex rear storage box.
Helmut is offline   Reply With Quote
Old 06-16-2011, 12:36 AM   #22 (permalink)
rich450es's Avatar
Default
huh i did not know that .thanks bud
2000 foreman 450 es-s
the f**king pig
SOLD!
Hondaforeman.com stickers for sale .....pm me for details !
friend me on facebook
i love (.)(.)s
Old 06-16-2011, 12:54 AM   #23 (permalink)
Helmut's Avatar
Default
No problem. Yeah, the foot shifter shaft is easy to change on the longitudinally mounted engines, once you get the rear crankcase cover off.
2000 Foreman 400
2004 Grizzly 660
Old 06-16-2011, 02:35 AM   #24 (permalink)
scottl1346's Avatar
Send a message via AIM to scottl1346
Default
sound like the wires got switch! my carburetor did the same thing when the little heater wires broke on the bottom i put them back on the wrong way and i layed it on the frame and every time it popped the fuse when i turned they key on and i couldn't figure out why or theres something screwed up in the shift motor itself.
02 foreman 450 ES
Wiseco high comp piston
2 inch HL lift kit REMOVED
super ATV front disk brake conversion
Super ATV Rear disc conversion
27" zillas on OEM wheels
14% gear reduction
HMF ECO system exhaust
diamond plate bash plate and cv boot guards
Super-winch 2500lb
custom LED brake lights
fan switch mod
rear progressive 512 shocks
100w shark audio system
scottl1346 is offline   Reply With Quote
Old 06-17-2011, 10:13 AM   #25 (permalink)
Honda Lover
mission's Avatar
Default
heck, i might want to change mine over to "s"
98 foreman 450es
mission is offline   Reply With Quote
Old 08-19-2011, 08:56 PM   #26 (permalink)
Honda Lover
bama450's Avatar
Default
im gonna convert mine over to "S" too, i have an 04 and i'm sick of that **** electric shift, all it does is mess up, i had it workin and washed the bike off and it quit workin!! ahhhhh!!! now i can't get it to work at all, i charged the battery, took the battery out to charge so it would reset, cleaned the wire harnesses with electrical cleaner, then filled them with di-electric grease and still nothing i'm gonna play with it some more tho., but if i'm gonna spend money on it i'm gonna buy that shaft and shifter, and a set of floorboards, i think i seen them on ebay.
and i sold this rincon so i have to change my name now, lol i put 28s on 450 without lift and they clear great!
2013 Brute Force 750
30" Moto Monsters
MSA diesel M12 wheels
HL 2" lift
Custom Split tubes audio
Soon... Custom rad relocate, custom exhaust mod, HIDs, programmer, clutch springs
2005 Honda Rancher 350ES
1000 miles, 150 hours,
all stock
http://www.youtube.com/user/weldermatt07
bama450 is offline   Reply With Quote
Old 08-19-2011, 10:01 PM   #27 (permalink)
Honda Lover
bama450's Avatar
Default
Stevejere, i just went out there and checked mine is doing the exact same thing, it works when i pull it off, but as soon as i get in popped in postition it goes to blinking again, and my carb heater wire is broke, but i'm not blowing any fuses, they all look good, i will have to go see if it is touching the frame or something??????? what did you end up doing with yours????
30" Moto Monsters
HL 2" lift
all stock
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
