450 fe shifting problems need help please - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 6 (permalink) Old 08-02-2010, 04:56 PM Thread Starter
i have a 03 450 fe . When I am in 5th gear and run it up to about 27-30 mph the gear indicator will start blinking. You have to stop shut it off and go back to neutural start it up and will shift fine till you hit 27-30 in 5th again. It has done it 4th i think once or twice too.
dannyjsj1 is offline
post #2 of 6 (permalink) Old 08-02-2010, 05:19 PM
Administrator
toodeep's Avatar
Garage
Welcome to the forum, count the number of flashes and that is a code. The retrieval process is at the top of 450 section in the FAQ links.
toodeep is offline
post #3 of 6 (permalink) Old 08-02-2010, 08:02 PM Thread Starter
it flashes 3 times what is angle sensor
post #4 of 6 (permalink) Old 08-05-2010, 12:21 AM
Mine did the same thing twice. The first time it was the angle sensor, the second time it was the speed sensor. Mine is a 2001 which doesn't put out any codes. Neither is hard to replace, but it will set you back a few bucks. I believe the angle sensor receives the signal when you shift and results in the transmission changing gears. Not sure why it will always go up through the gears, but not back down
mharteis is offline
post #5 of 6 (permalink) Old 08-05-2010, 01:00 PM
Administrator
toodeep's Avatar
Garage
The angle sensor is located on the front of the motor next to the shift motor. It tells the system how far to shift so it gets a complete shift without going too far and damaging something.
toodeep is offline
post #6 of 6 (permalink) Old 08-08-2010, 11:49 PM Thread Starter
Thanks for the help going to try angle sensor then speed sensor
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
