es problem and where is the angle sensor - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 9 (permalink) Old 10-05-2009, 03:29 PM Thread Starter
i have a 03 foreman 450 es just got it a couple of days ago rode fine til we took it to the trails yesterday bout half way thru the ridin it startede not wanting to shift but i figured out that i could turn it off and then back on and it would shift fine then it got worse i cut it off and it wouldnt shift at all so we had to pull it with my raptor and then cause it was in gear it started but then it got stuck in reverse so we had to back it out of the trail from what i have read i think it might be the angle sensor but i don know where the sensor is is there a diagram or something showing where it is and its showing 3 N flashes i think that means that its the angle sensor any help woulb be great thanks
86 325e
99 328i
97 chevy tahoe z71
04 honda foreman 450es bored to 507CC 27x10x12 front 27x12x12 rear super swamper vampires
05 yamaha raptor 350 ITP Mudlites
02 yamaha warrior 350 ITP HoleShots front and rear
brrymiller@yahoo.com is offline
post #2 of 9 (permalink) Old 10-05-2009, 04:21 PM
Administrator
toodeep's Avatar
Garage
barry.
The angle sensor is located on the front/lower/center of the motor. It sits beside the shift motor and is covered with a small tin shield. It takes a 10mm socket to remove the shield and I think a 4mm (pretty sure on that size??) allen wrench on the sensor. When replacing it make sure you get the o-ring on the new one.
1987 350D (work in progress)
toodeep is offline
post #3 of 9 (permalink) Old 10-05-2009, 04:37 PM
twiggy's Avatar
Send a message via Yahoo to twiggy
I've also had the same issue with my 03' 450. The angle sensor fixed the problem. its about $60 at the honda dealer.
03' Honda Foreman
HMF pipe
ITP mud lite's
2 55w driving lights
2" lift
300w stereo system
diamond plate skid plate
and CV guards
saddle bag
cargo box
blacked out wheels
1,500 LB winch
twiggy is offline
post #4 of 9 (permalink) Old 10-05-2009, 05:48 PM Thread Starter
QUOTE (toodeep @ Oct 5 2009, 03:21 PM)
Quote:
barry.
i found the sensor how do u know if its bad or not and do u no how much a shift motor is
86 325e
99 328i
97 chevy tahoe z71
post #5 of 9 (permalink) Old 10-05-2009, 06:07 PM
Administrator
toodeep's Avatar
Garage
Post #13 in this thread is how I like to check them, the numbers should be steady and not jump up and down on the meter, meaning the numbers should only increase or decrease.
http://www.hondaforeman.com/index.php?showtopic=17928
toodeep is offline
post #6 of 9 (permalink) Old 10-05-2009, 07:12 PM Thread Starter
QUOTE (toodeep @ Oct 5 2009, 05:07 PM)
i read on on of the forums somewhere that if u cant shift it manually either than it is a mechanial problem that it is probably the shift drum bolt that it has backed out or broke what is ur opinion on this and do u know exactly where the shift drum bolt is
86 325e
99 328i
97 chevy tahoe z71
post #7 of 9 (permalink) Old 10-05-2009, 07:56 PM
Administrator
toodeep's Avatar
Garage
That is correct, if it doesn't shift manually it could be the bolt, the shift plate or the shift arm. The front engine cover has to be removed to inspect them.
toodeep is offline
post #8 of 9 (permalink) Old 10-07-2009, 11:56 PM
Honda Addict
yellowsubmarine(cb)'s Avatar
Part 22
http://www.motosport.com/atv/oem.php?make=...mp;groupId=9849
04 Foreman 450 ES w/30" S-Backs, ITP SS 312 Wheels, Highlifter 475cc BBK, WebCam cam, 14% Gear Reduction, EPI Clutch Kit, DGL, HL 2"Lift, HL Springs, HMF Utility Exhaust & jet, Triangle ATV Snorkle, K&N w/Outterwears pre-filter, Gorilla 3k lb winch, HL Diamond Plate Bash Plate & Axle Guards, Custom Audio Pipe w/ Polk Marine Speakers, Custom Fuel Guage Light, Headlight Lifted, 8000k HID Lights, Manual Fan Switch, Rear Utility Light, Xtreme Disc Brake Conv
yellowsubmarine(cb) is offline
post #9 of 9 (permalink) Old 10-09-2009, 01:39 AM Thread Starter
QUOTE (toodeep @ Oct 5 2009, 06:56 PM)
thanks for the help i found the problem somehow the shift control motor locked down and it was causing me not to be able to shift manually but i took the shift motor out and just put the cace that holds it back on the front case and i can now shift manuslly with no trouble at all do u know where i can find a shirt control motor for cheap it is a real pain having to reach down and shift with ur hand the cheapest motor i could find is $155 so any cheaper would be great thanks for the help
86 325e
99 328i
97 chevy tahoe z71
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
