Oil Seal on Gear Shift Shaft - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 5 (permalink) Old 01-05-2009, 09:12 PM Thread Starter
What would have caused the seal around the manual shifting gear shaft to dislodge? I understand that high pressure in crank case would cause this seal to dislodge but what would have caused the pressure? I pushed it back into place and seems to be holding. Should I replace the seal anyway?
pickle-man is offline
post #2 of 5 (permalink) Old 01-05-2009, 09:41 PM
Check your crankcase breather hose, it could be plugged or possible the little white elbow into the air box. It happened to me. With regards to the seal I would change it next time you change oil. ( Make sure you keep an eye on it though if you wait)
Wanger is offline
post #3 of 5 (permalink) Old 03-15-2009, 05:44 AM
HI guys, sorry to resurect an old thread but i have a leaky seal here too, is it esy to change? as in remove the pedal, pull the seal out and knock in a new one? or is there more to it?
Thanks
krissvdh is offline
post #4 of 5 (permalink) Old 03-16-2009, 12:36 PM
Honda Lover
honda450s's Avatar
thats all you have to do. pretty simple.
1999 Honda Foreman 450ES SOLD
2" lift Dual Snorkels
HMF Utility exhaust with homemade snorkel
Dyno jet kit
K&N filter
Warn 4-2-4
28" Mudzillas on Black Delta steel rims.
4000IBS Viper Max winch with synthetic rope
Maier Hand guards
Clutch kit
14% Gear reduction
HL Front Disc Brake conversion. love it!
HL Spool locker
82 Chevy Silverado 4X4
350 SB bored .30 over
Straight piped, headers, dual flowmasters
8" suspension lift, 2" body lift
38" TSL Thorn with 16" Eagle Alloy Rims
Dana 44 front diff, GM 14 bolt FF rear
TH400 Turbo tranny
NP 205 T-Case
honda450s is offline
post #5 of 5 (permalink) Old 03-17-2009, 12:06 AM
dirty4man's Avatar
just make sure the clean the shaft before sliding the new seal on. Use a fine grit sand paper to clean it up.
98/01 Foreman 400/450 Halfbreed with to much to list according to the site
dirty4man is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
