What kind of gear oil for front & rear differential? - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
post #1 of 5 (permalink) Old 09-01-2008, 12:48 PM Thread Starter
Honda Addict
04honda's Avatar
I need to change my front and rear differential oil from where I sunk my foreman. What exactly brand/weight and how much do I need to do this? THANKS!!!
04honda is offline
post #2 of 5 (permalink) Old 09-01-2008, 01:08 PM
Honda Lover
honda450s's Avatar
i use 80w 90 gear oil. and i havent had any problems. some people use 85w 90. idk what the difference is
1999 Honda Foreman 450ES SOLD
2" lift Dual Snorkels
HMF Utility exhaust with homemade snorkel
Dyno jet kit
K&N filter
Warn 4-2-4
28" Mudzillas on Black Delta steel rims.
4000IBS Viper Max winch with synthetic rope
Maier Hand guards
Clutch kit
14% Gear reduction
HL Front Disc Brake conversion. love it!
HL Spool locker
82 Chevy Silverado 4X4
350 SB bored .30 over
Straight piped, headers, dual flowmasters
8" suspension lift, 2" body lift
38" TSL Thorn with 16" Eagle Alloy Rims
Dana 44 front diff, GM 14 bolt FF rear
TH400 Turbo tranny
NP 205 T-Case
honda450s is offline
post #3 of 5 (permalink) Old 09-01-2008, 06:35 PM
Send a message via MSN to AllHonda Send a message via Yahoo to AllHonda
AllHonda is offline
post #4 of 5 (permalink) Old 09-02-2008, 05:18 PM
I use 75W90 synthetic hypoid gear oil (actually quite unlikely you would find an 80W90 or 75W90 that is not a hypoid oil, if it is for the rear axle of any pickup truck, it is a hypoid oil).
You may also find after changing your front axle gear oil that you have a creaking noise when you take corners if you have the Honda limted slip front axle as I do. To stop this, just add a very little bit of limited slip additive which you can purchase from any GM or Dodge dealer. In a GM limited slip axle, you use a small 8oz bottle for approx. 2.5 quarts or liters of axle fluid, and I think the Honda front end only holds about 300ml or a third of a quart. So you would only need an ounce of additive.
1999 Foreman 450ES
26" Carlisle ACT XLR's
Winch
Kimpex Plow
Passenger Seat & Pegs
Heated Grips & Thumbwarmer
Prefex Long Travel lift front and rear
1" custom spring spacers on stock front springs
GM DOC is offline
post #5 of 5 (permalink) Old 09-02-2008, 05:28 PM
Some synthetic gear oils already have the friction modifier in them.Look on the bottle,it should say.
2006 Foreman 500 S
25" GBC Dirt Devils
26" Kenda Executioners
ITP silver steel wheels
Warn multi-mount
mile marker 2500 winch
VDO cyl. head temp. gauge
HMF utility series muffler
Dynojet kit/running DJ170
Yooperforeman is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
